dieseldogpi
Different question, issue I just noticed. Seems like there are a couple of times while playing, the flippers will turn off as if a tilt or the slam switch was triggered. The tilt is disabled (no weight) and the slam switch is missing. This ONLY happens when the Crane is in the up position (crane is near the yellow wire ramp). nothing shows up on the dmd as a tilt or anything, so I am confused as to how to diagnose this. Problem seemed to have gotten worse since I fixed the shaker motor, so my gut feeling is switch adjustment, but I have no idea what rule would cause the game to go into a tilt type mode. Its not that it turns off or anything either, looking at the dmd you would think the ball was still in play. Once it drains, everything is fine for the next ball. Any ideas??
