boy141
So I bought another arcade after getting the last one up and running. This time I have no neckglow. It's a 25K7197 with a p538 stamped on it. The game is playing blind. I went with the flow chart and started with the fuse. we're good on that. then I checked on the R301 B+, one side is 74 volts while the other is 54 volts. Chassis was repaired in '97. Just wanted to see if I should replace R301 or is it something else? Also, where do I buy R301? The highest watt for that resistor is 10watt. I can't find a 15watt.
Thanks in advance!
Thanks in advance!
