So, I recently capped it and put a new flyback and HOT and it has been working great. I then recently put in a new PCB in the cab and the picture was upside down. I took the chassis out to swap the yoke wires, put it back in and now the fuse is blowing. I replaced the fuse and it blew again. I don't know if this would cause the blown fuse but the anode clip plate on the new flyback fell off. As a result the anode clip became loose and fell off completely. I am planning on soldering it back on when I can get back to working on it.
Would the loose anode clip cause the fuse to blow?
I know that I didn't swap the wrong yoke wires as I was very careful not to swap the wrong one's.
What else could have caused this and where should I start looking? Any help is much appreciated.
Torin
Torin
