Another issue new monitor
Deadpool66
Minnesota
So apparently every game I have is going to need a cap kit or somthing. I was playin around with my dynamite cop and low and behold I notice the monitor brightens and darkens at random becoming more intense the longer the display is on. Is this somthing I might be able to fix today?
Im going to order cap kits for all 4 of my 25s in the mean time.
If you have the caps on hand then sure.
It is most likely a failing cap causing the intensity you are looking at. It could also be a cold solder joint but I'd lean heavily toward a failing cap.
Most of the electrolytic caps used in these monitors were only designed to last about 8 years. This is why so many problems tend to be caused by failing caps.
