It's an Artic mini. Mars and Devil Fish came in it officially. However they were very commonly used for bootleg games like Frog (ger) and Scramble.
The cab sucks.. the back is permanently attached, your only access is through the lower front that swings out with the coin door.
The power to the marquee light is cut into the left side just under the thin laminate.
The speaker is mounted on the right rear bottom facing back!
The monitor chassis is attached to the left side so you must detach the wires to the tube to remove either part or rotate the tube for horizontal/vertical -- again, all from the front.
The control panel is at most 4" of vertical space.
The coin door is the same as is often found on original Universal cabs.
Check the for sale group--someone is selling 3 of these somewhere and they had bootlegs in them and I put some details on them there yesterday.
