roburt
Hello to all. What I've got is an 1981 Centipede with a G07 chassis. It was doa. Got it to play blind & found a cracked flyback. Ordered a cap kit, hot, flyback, & fuses. Installed said items, reflowed headers, and checked my work and still no neck glow. Followed the flowchart & now I'm not sure what to do (first time working with a monitor). I have 110 to chassis. Both transistors are not shorted. Both chassis fuses are still good. I'm getting 119.6 vdc at the big resistor (white wire) and 165.5 vdc at the back end. Flowchart says it should be around 120v & 145v. I am also hearing some hissing from the chassis. I turned out the lights & see nothing but darkness. At this point, I'm lacking direction. I'm looking for some advice before I redo everything & try again. Any imput would be very much appreciated. Thanks.
