Another coin door light question
JC Arcade
New Jersey
I'm wiring up a multicade, and I have a thicker gauge wire sending the 12v to the coin door lamps directly from the PS, but I'm using the thinner ground wire from the JAMMA harness as the ground from the lamps. Is it okay to have them mismatched like this? Or do both the ground and power wires going to the lamps need to be the same gauge?
It can be mismatched. Just make sure the smaller wire can handle the current which I'm sure it can for just a couple coin door lights.
