Madaracs
I recently bought a Tron UR with a bad PCB in it. I didn't know what the issue was with it so I decided to try it out in my cocktail machine to make sure it was a board problem. The board worked! Well sort of. It worked once. The next time I turned the game on it went into a reset mode:
Grid pattern, couple of colors, grid pattern, repeat.
This is not my video but it is the exact symptoms my board is having:
The person who posted this video ended up finding out that his slam switch was stuck. That's not the case with me. I put my old Tron board back into the cocktail and it's working perfectly again.
So I know the problem is on the PCB. I was wondering if someone could tell me which parts might be the culprit causing a reset like this? Could it be some bad 2K RAM? Could it be a CPU issue? Or is there a cap that's not getting enough power?
Ideas are welcome!
Ideas are welcome!
