Amplifone question
don1400
Green Bay, Wisconsin
Hello guys,
Was wondering if there an absolute way to tell if one of the three color guns is out of alignment making it impossible to do good convergence? I have spent a ton of hours trying to converge my SW Cockpit Amp to no avail. I know vectors are a pita to converge and will never be perfect it seems no matter what I try the blue vertical lines on left of screen are always too far out to the left to correct, if I tilt yoke to correct, then the vertical blue lines on the right of screen move out of alignment. I have tried another yoke, and new rings and the results are basically the same. I'm following directions in the 6100 book plus two other sets of slightly different directions I found on line. When I got the game yoke was loose, wedges were missing and rings were on backwards so I had to start from scratch. Anyone have any thoughts?
Sounds like you need to get your hands on some of those magnetic shunt strips. FWIW a vector will never be 100% perfect but you can get it real close. Also ensure the blue dots are about 1/4" away from each corner (and round not strecthed) and you go though the BIP test.
Hi Deadly,
I have over a dozen or so of the magnetic strips, since they work primarily on the corners I'm still not able to get 9 o'clock position in line on left of screen. As you know
the strips affect other areas as well so I can only do so much correcting. I've attached a screen shot of what I am working with now maybe you can offer advice, I know Vectors will never be 100% but what I am working with isn't real close. I have the 4 blue dots about 1 inch from corners, was told to do so by a KLOV'r who rebuilt the deflection board and I have the BIP test set correctly. I will check the blue dots shape and re-adjust them if necessary and move them to 1/4 inch from corners. What affects the shape of the dots? The diamond pattern adjustments? BTW the screen shot is the best I could get.
Appreciate the help
when you put a strip down behind the yoke, move the strip from side to side... almost like you are rotating it a bit on the spot is how I can best describe it.. I find sometimes if you don't just put then straight in you sometimes get some better results.
