Amplifone part
kingpin
Gothenburg, Sweden, Sweden
Since I have a problem degaussing my monitor (it never degauss and the picture is a bit screwed in the upper parts of the screen) I think I need the positor/thermistor/PTC (or whatever the part is called).
Does anybody know of a source for these or does anybody have 1-2 to sell?
TIA!
So did you end up shaking yours to hear the rattle?
I have a few, freight might be $7 or $10 bucks though from AU
They will be second hand, but I would send non rattly ones
No cost, just freight. Or wait for local, it's up to you :)
Heya!
Nope, I didn't, I just figured that I would need it sooner or later anyway I guess...
I'll PM you if nothing else turns up, thanks dez! :)
Did you get the PTH451C from ebay?
Did it work?
Reason I ask is the schematic calls for a 3 ohm 60V look at the part number
in the atari manual.
Atari part # 110012-030 - 3 ohm, 60 volt, +/- 10% Positive-Temperature-Coefficient Resistor
ebay part has PTH451C 142(M)51
Most of the ones I've seen on the board have PTH451C 35(M)19
In the muRata data sheet the only 3 ohm device listed is PTH451C3R0Q11
Could you measure the resistance of the one from ebay?
Did it work?
I got a few from this seller, and can measure if you like :)
Yes Please. Also could you post the part number of the one on your amplifone board.
I assume the ebay one has the number I posted?
I could be wrong (it may just be a date code) but I'm thinking that the numbers 35 and 142
are 3 digit resistance values like
35 = 3.5 ohms Only 2 digits would be point values
350 = 35 ohms
351 = 350 ohms
352 = 3500 ohms
so 142 may be 1400 ohms
Just asking.
I got two Amplifone deflection boards that hav parts "borrowed" from that I want to rebuild. Both posistors have gone and so I would like two......Dez do you still have some ?
