ArcRevival
Just finished up an Amplifone rebuild and after the current one I am on is done I will be caught up. If anyone else needs one done let me know and you can be next in line. I could probably get one more done before the Holidays.
It's not cheap but the rebuild is pretty extensive. I have now done about 15 sets of these for klovers in case you need references. The price is $225 per board ( HV or Deflection) or $400 for both. If your board is missing an extensive amount of parts or in worse than normal condition, the price might have to be adjusted. If you have a new working flyback all ready, I might adjust the price down for that too.
This is NOT a cap and slap. I spend on average about 10 hours on these. Many parts are replaced and upgraded. Some but not all of what I do:
1. New caps
2. Hard wire 1 ohm jumpers
3. Replace XY adjustment pots
4. Remove and reinstall harnesses.
5. New HV flyback
6. New voltage regulators ( HV and Deflection board)
7. New pots on HV board.
8. 50ohm resistors moved to heat sink ( keeps them from cooking the HV pcb)
9. Some diodes are replaced and upgraded.
10. Some resistors are replaced and upgraded.
Some feedback ( Really appreciate it !)
http://forums.arcade-museum.com/showthread.php?t=187634&highlight=arcrevival
http://forums.arcade-museum.com/showthread.php?t=177325&highlight=amplifone
What I won't do :
1.Hold on to your board for months without communication.
2. Only troubleshoot and fix a specific problem for less money ( these monitors have too many trouble spots that need to be addressed )
3. Give you a list of every part and where I get it and explain in great detail what I do so you can just do it yourself. I know that may sound rude, but it would take me quite a while to list it all and explain it all. I would rather spend that time rebuilding yours so I could charge you
Happy Holidays.
1. New caps
5. New HV flyback
What I won't do :
Happy Holidays.
