Amplifone Hv woes
Deadly
Gresham, Oregon
This has to be the crappiest board I've had to work on.
WARNING - REPAIR NIGTMARE DEAD AHEAD!
Someone soldered 10 resistors in backwards (2 of which were the incorrect values) , used an NTE379 instead of a BU406D, 7924 was blown in half, 7824 was blown, both 1N4001's were cooked as well as both 5w 50ohm resistors and lastly a ground wire was loose. This has the original red flyback so before I order a new one I thought I'd post here.
So now knowing what I have replaced/fixed I have hit a brick wall and need help. I have no picture, no LED lit on the HV and the BU406D gets screaming ass hot. VR1 registers +30 and +11.00 while VR2 is spot on for -30 and -24. Deflection board works perfectly with other HV board I have.
Any help/suggestions greatly appreciated.
How on earth can resistors be soldered backwards ???????
First: desolder the BU406D. It's perfectly safe to run the board without it and enables you to troubleshoot the first sections without problems.
See if the HV generation circuit produces a block-wave.
I do assume you've read the Amplifone FAQ ?
LOL!!! Sorry guys it was late when I posted. I meant DIODE you bastards!
@Level42 - I don't have a scope. Checking wave form NOT an option.
I would tend to be with Tester007 to replace the flyback but before I did I figured I'd try to revive it hoping the flyback was good. About all I can think of is to replace the 555 and if that doesn't work then flyback is next. Unless of course someone else comes in with a different idea ;)
You have about as much chance on having a good red as winning the lottery ;)
I'm with Tester....
Get a Cinelabs HVT...
The gold band on resistors runs north and south, and must be on the west side, unless mounting on the solder side then east is ok.
:D :D :D
Seriously, we were taught at electronics education to solder them all in the same orientation so that the color band would be easier to read. Not a bad idea, but who reads those bands ? I measure all the time.... :D
