Amplifone HV Printed board
Do you have the "magic part" MCI for new boards ?
I found this page regarding the MC1 Can (From here)
They miss-spelt amplifone so it is hard to find in a search
MC1 is labeled as "Magnetic Correction 1", hence you would be right, this
compensates for not having a yoke. But, if you read what I had to say about
replacing this - with 3 10mh chokes - this may be a possibility in a new
circuit.
Overall, the amplfione HV unit is a very simple design that could most
likely be adapted to any HV transformer.
Interesting
The SW doc set I bought from e-bay some years ago actually contained an updated schematic of the HV board showing the resistors (R20 & R21) and the extra added diodes (CR5 & CR6). The latest Amplifone FAQ mentions that the resistors were not in the schematics IIRC so I guess this is pretty rare ? Don't know.
I've attached it to this reply.....
Thank you :)
so that means the mod will look like this (smaller) IE from a Beige Board
click
2 wire links are needed (see above)
Thanks for the help Level42 and others who replied :cool:
The shunts end up in the gap near the MC1 can
Yes that seems to look correct. I'd suggest to move the left power resistor a bit more to the left if possible. The more evenly the tranistors and resitors are spaced over the heat-sink, the better I guess....
I think the beige boards already have positions for the diodes right ?
The diodes are just soldered on to the solder side. (3 diodes)
OOPS best to add them too :D
And it is easy enough to move the 1st resistor now so will do
Cheers
3 X Diodes added
2 x Medium size wire links needed
2 x Shunt resistors needed
Time to get these started I think
Thanks for the help :cool:
Have you made any progress with this project dezbaz :)? Like many others around here I have a 19" Amplifone with no HV board.
While every component is readily available the MCI can to my knowledge is not. There is a guess made as to what it really does or what it is.
So without that component this project is a mere PCB swap to get rid of burned up one ;)
Might want to ping Daviea as I believe he is also working on a solution.
I need to soon, but other projects, including my recent starwars c/pits, have put this off.
Do you realize, this is a BARE PCB manufacture? You will need to source the parts. :D
MC1 is explained earlier in this thread. I have already purchased the 3 x 10mH inductors to test it out on my cab.
I guess we just have to try. :)
Please note guys, I am in no hurry to do these, as I have a working amplifone board, but I will be doing it, in time.
If anyone is interested in a BARE PCB, then please jump on the list
I will edit page 1, post #1, every time someone asks to be included.
I am hoping to get these done soon
I have asked a reputable business owner, who actually designs and sources quality pinball and arcade parts and solutions.
I have directed Mike to this thread, so I am hoping he will chime in soon.
His name is Mike, from Homepin.
About the MCI: why hasn't anyone x-rayed one yet ? It's been done before with the sealed in IC's on various PCB's....
Would we expect to be able to see anything on an x-ray, I actually do think so....
I do have a friend who does x-raying in hospitals....mmm, I'll drop him a question....:D
MCI is actually MC1
Magnetic Correction.
Apparently it's just a choke
Quantum didn't have the diodes (typically a blue PCB), the revision used in Star Wars did (usually green or beige). It's easy enough to add them to the earlier revision though.
I designed the proposed PCB with spots for all of the mods incl the diodes. If not needed, people can leave them off :)
The entire Amplifone PCB set in my SW cockpit was original (all the same Serial nr.) and I have blue boards. The HV did have the diodes (on the solder side) factory modded in as well as the resistors (on the parts side).
