shilmover
Just picked up a SW with an Amp (http://forums.arcade-museum.com/showthread.php?t=144650).
The first monitor I ever fixed was an Amp so it was a while back.
It is a 25" model with the original Red flyback.
Here is the strange thing about the monitor. When I start it up:
- The red led (spot killer?) comes on, then off after a second or so and stays off
- I can hear chatter from the monitor (if I unplug the monitor, there is not chatter). It also seems as though the chatter is changing (as I would expect in a working monitor drawing different vectors.
Any thoughts on where to start? Fuses are all good, nothing seems burned on the boards.
