AMI W-80 Wallbox on S120 Stepper, wont home properly
brotherhay
Port Edwards, Wisconsin
So, I have an AMI F-80 Juke, with W-80 Wallbox connected to a S-120 Stepper. 4 of the 6 harnesses are plugged in for the stepper, I was under the assumption this would work. I have the L-235 xformer assembly installed also, and as it stands the wallbox lights up, and takes credits. If I manually put the wiper arm on the home position it sits idle fine. If I drop in a dime, i see the dime magnet switch trigger, but get no credit light. No lights in the page display either, but the credit glass on top is lit.
If i press a button, the wiper arm just goes in circles, never going home again and stopping. The stepper is clicking along with the wallbox, and a bunch of selections are being made. I have the manual for both Juke and Wallbox. The wallbox manual has a Trouble shooting chart, but seems theres multiple problems here. Where to begin? Hoping someone here can help me out.
Ok, got it fingered out. The wiper arm is supposed to do one cycle, then there is a gear assembly behind that that should be triggered after the cycle, pop out the selection button and lock the wiper back into the home position.
The assembly that was failing had seated itself on top of something that it shouldnt have been, so i just pulled it out, and it seated itself properly, and now works.
