Americoin junkyard gear
Iggs1
Brecksville, Ohio
Hello I have a junkyard by americoin. I need the motor or the small gear in the motor assembly that actually lifts the cars. 3d printing or someone who will make just 1 gear? Any info would be great
Mark
Mine failed as well.
Apparently I found out from people here on the board that the failure your mentioning is fairly common due to the motor having both plastic and metal parts.
To my knowledge as of right now there is no replacement available.
I was lucky enough to have a spare motor.
Here's a photo of the broken part inside of the motor.
It's the black gear that keeps losing its teeth.
Good luck with your search.
Mark
I am going to use a 20rpm version instead of the 15rpm version. If the one i have works, i will post the 10 dollar solution i have found.
I might build a few brackets so we dont have to hack the old motor frame apart. I wonder if a plastic bracket will work? Maybe a 3d printer job is in order?
