Aluminium Stickers the 2e batch
etienneodk
Breda, North Brabant, Netherlands
As you might have read in this topic:
http://forums.arcade-museum.com/showthread.php?t=174045
it was a huge succes, bigger than i expected.
I have decided to take new orders for another run.
I have to collect a full sheet to justify the costs.
you can understand that 1 sticker would be way too expensive, so the more "orders" the better i would say.
I cannot give a time of printing since i dont know when the sheet is full.
Anyway, the sheet measurement is 100 x 70 cm. and calculating roughly there fit 70 - 75 etikets in one sheet (depending on the size ofcourse)
once the sheet is full, i can let it print, or if there is more than one sheet, even better which reduces the costs.
Based on the last run, the costs per etiket is 3$ and depending on the quantity the shipping may vary.
Again, like the first run, the idea is not to profit from it.
if you like you can read more about it in the following thread on DLF:
http://www.dragonslairfans.com/smfor/index.php?topic=2454.0
i will display the pics of the etikets that are here in the next post, and if there is anything that is not there which you like, i can create that if there is a good picture / scan available with measurements in millimeters. (yeah yeah i know you guys like inches but i am european hey :) )
also in the next post i will keep track of the received orders.
Oh and before i forget, please provide the data if you want that to be printed inside (serial number and type)
Orders received:
Krajkerjac: (Font: "1942 report")
(Ready in sheet)
3x #4 (Model 298-01, Serial 0069, 110, 3), 1x (Model 383-01, Serial 0069, 110, 3), 1x (Model 290-01, Serial 0069, 110, 3) alu
3x #5 Model 36800 Serial 00069 alu
1x #9 Serial 00069 alu
3x #11b Serial 00069 alu
3x #12 alu
Gatordad:
(Ready in sheet)
1x #4 Blanco
1x #12
Toolguy: (font: #3: courier new)
(Ready in sheet)
1x #4 (Model 298-01, Serial - 688, Volts - 110, Amps - 3.)
1x #10
1x #14 Model ASTEROIDS CABARET, Serial no. - SAS 688. (must be all in caps like I typed please)
Kspiff: (font: #3: courier new)
(Ready in sheet)
Assault:
#5b (blank for now)
#11 (no #11a for now)
#12b
#17
EPROM:
#11 (#11a = serial 0107)
#5b (model 49900 / serial ESC0107 / 120 / 2)
#12b
#17
Star Wars:
#12b
#17
#11 (#11a = serial 10044)
#5 (model 27900 / serial UR10044 / 120 / 4.5)
CS:
#12b
#5 (model 48500 / serial UR05007 / 120 / 4.5)
#17
#11 (#11a = serial 05007)
PB:
#5 (model 40900 / serial UR02193 / 120 / 4.5)
#11 (#11a = serial 02193)
#12b
#17
Tempest:
#11b (serial 08011)
#5 (model 289XX / serial UR08011 / 120 / 3)
#17
#12
APB:
#5b (model 46700 / serial UR02095 / 120 / 6)
#11 (#11a = serial 02095)
#12a
#17
Warlords:
#4 (blank for now)
#12
#19
720:
Millipede:
#19
#12
#11 (#11a = serial 10683)
#5c (model 36800 / serial UR10683 / 120 / 3)
#20 (No. A 7643)
Spare (all blank):
2x #4
2x #11 (#11a blank also)
2x #11b
2x #17
2x #19
2x #12
2x #12a
2x #12b
2x #5
2x #5b
2x #5c
Ballytablewiz:
(Ready in sheet)
2x #4 1x blanco, 1x printed (Model #: 383 XX, Serial #: 0001, Volts: 120, Amps: 3) (Font: "1942 report")
1x #5 (Model #: 38300, Serial #: 0000001, Volts: 120, Amps: 3) (Font: "dot matrix")
2x #11
5x #11a - Serial #: 00001 (Font: "dot matrix")
1x #12 - print on white
2x #12b - print on white
1x #14 - Blanco
1x #19 - print on white
Bungy:
(Ready in sheet)
3x #11 (no rounded corners)
3x #12b (white)
4x #5 2x Blank, 1x(Model: 38300, Serial: UR00001, Volts: 120, Amps: 3), 1x (Model: 38300, Serial: UR00501, Volts: 120, Amps: 3)
AsteroidsNut:
(Ready in sheet)
12x #12 (white)
YODAAinMN: (font #5: travelling typewriter)
(Ready in sheet)
1x #2 (Model: ESAD s/n: 101732 Volts: 230 Amps: 2-5)
1x #14 (Model 298-01, Serial - 693, Volts - 110, Amps - 3)
Wldfire: (font #5: travelling typewriter)
(Ready in sheet)
1x #4 (Model# 225 XX Serial # 11061 Volts = 110 Amps = 3)
2x #5b (Model # 3924 Serial # 119437 Volts = 110 Amps = 3)
2x #11
2x #12 (white)
Muerto: (Font: "1942 report")
(Ready in sheet)
1x #2 (Model# MTGI Serial # 00001 Volts = 230 Amps 2-5)
1x #4 (Model# EDGA Serial # 01975 Volts = 110 Amps = 3)
Level42: (font: #3: courier new)
(Ready in sheet)
2x #2 (Model: EDST Serial: 129351 Volts = 230 Amps 2-5)
1x #20 Q*bert
4x Steeringwheel emblem Harddrivin white
SuperUlly:
(Ready in sheet)
2x #17 white
4x #18 White
5x #3 Alu
2x #10a Alu
4x #21 Alu
2x #15 Alu
1x #23 Alu
2x #24 Alu
1x #20 Alu
6x Taito equipment white
1x Shiny Gremlin alu (to be verified)
TravisH: (font #5: travelling typewriter)
(Ready in sheet)
4x #4 (2x Blanco, 1x Model 298 XX Serial number 6809, volts 110, amps 3, 1x Model 215 XX Serial number 9267, volts 110, amps 3)
4x #19 (Alu)
Bencao74:
(Ready in sheet)
24x Jamma (space of 9 regular stickers so counts as 9 stickers)
10x #1
10x #4
10x #5
10x #11
10x #12 (white)
Angry_Radish:
(Ready in sheet)
1x #11b serial#01128
JoeB1355:
(Ready in sheet)
3x #4 (font: travel typewriter), Model 215 XX , Serial 26360 Volts 110 Amps 3, Model 236 XX Serial 7675 Volts 110 Amps 3, Model 236 XX Serial 5831 Volts 110 Amps 3
2x #5a (font:dot matrix), Model 289XX Serial 04305 Volts 120 Amps 3, Model 289XX Serial 07226 Volts 120 Amps 3
2x #5d (font:dot matrix), Model 30202 Serial 01418 Volts 120 Amps 3, Model 30202 Serial 01502 Volts 120 Amps 3
4x #11
20x #11a (5x serial 04305)(5x serial 01502)(5x serial 01418)(5x serial 07226)
7x #12 (WHITE!)
don1400: (white)(no round corners)
(Ready in sheet)
2x #17 red warning labels
3x #19 red warning labels
1x #12b
1x #20 ALU serial A1928
EclipseEye: (font: #3: courier new)
(Ready in sheet)
1x #13 (Model: CABARET ASTEROIDS Serial No: SAS 79302)
Roadrunner000: (white)
(Ready in sheet)
20x #17 red warning labels
40x #19 red warning labels
10x #10a Alu
mystery_base:
4x #11 leftovers last run
Joeycuda:
2x #4 1x Model 23602, Serial No. 1120, Volts 110, Amps 3, 1x Model 225-02, Serial No. 1230 , Volts 110, Amps 3
1x #5 blank 120,3
3x #12 white
3x #19 white
2x #12b white
SimpleSi:
4x old taito coin insert decal
4x old Taito Coindoor decal alu (to be placed)
1: Zaccaria - Ready for Printing.
2: Irish Atari - Ready for Printing.
3: Irish Atari Alternative - Ready for Printing.
4: Usa Atari - Ready for Printing.
5: Usa Atari Alternative - Ready for Printing.
22: Zaccaria Coindoor Decal - (originally on white, printed on alu is ofcourse also possible)
let me know if you want white or alu for this one.
6a: Sega Hangon FCC ID (originally on white, printed on alu is ofcourse also possible)
17, 18 & 19: Red Atari Warning Labels:
8: Atari-Namco - Ready for Printing.
9: Dragons Lair - Ready for Printing.
10: Namco Bally plate - ready for printing.
Please note that this will be printed on aluminium sticker, not on a plate!
11: USA Atari inverted - Ready for Printing.
12: USA Atari FCC - (originally on white, printed on alu is ofcourse also possible)
13: Atari Cabaret IRELAND - Ready for Printing.
14: Atari Cabaret USA - Ready for Printing.
I will start the list!
3 of the #4 Serial 00069
3 of the #5 Serial 00069
1 of the #9 Serial 00069
3 of the #11 Serial 00069
3 of the #11a Serial 00069
3 of the #12 Serial 00069
Thanks! Put whatever model number you see fit! Gotta have a little fun.... ;)
Going to try and wait until I get back home to see exactly which ones I need to stay 'authentic'.
Id be in for one for my warlords
(1) number 4
model 290 02
sn 248
volts 110
amp 3
(1) number 12 as well
This will be the finishing touch.
This is a plate of course, but can you do it? Would you? All I have is this pic, I don't know the size of it.
Does any one else have an interest in it? This one is from a Galaga Cabaret.
I actually did already the vector of it:
But i dont have aluminium plates, just aluminium stickers.
here the story behind it:
http://www.dragonslairfans.com/smfor/index.php?topic=2454.msg31929#msg31929
it was #10 in the list, but as you might have noticed, i left it out ;)
The reason is simple, i heard that Rich from this old game has these as repro's, and i don't want to be in anybody's way.
But if Rich is ok with it, i can print this for you on alusticker which you can stick to a plate of aluminium.
Let me know your thoughts, and i'll drop Rich a PM.
it was #10 in the list, buy as you might noticed, i left it out ;)
The reason is simple, i heard that rich from this old game has these as repro's, and i dont want to be in anybody's way.
Oh OK, did not know about it.
Humm, I was just on the this old game site and did not see them.
I did these years ago and have been out of them for a while.
I dont have plans or time to do them again any time soon so feel free.
I did mine for a galaxian and IIRC the art looks alittle different
Ill dig up the file and post your welcome to use my vector file as well if youd like to do these
Okay, thanks !
I will put #10 back in the list then ;)
If you want it, be aware that it will be on the same aluminium sticker as the rest, and NOT on a plate of aluminium.
Put me down for:
2x #4 (blank/TBD)
7x #11
2x #12
6x #5:
4 with the following filled in:
48500
UR05007
120
4.5
and
40900
UR02193
120
4.5
and
46700
UR0209
120
5
and
36800
UR10683
120
3
and 2 blank/TBD
(^^For best accuracy btw the volts should be sort of left justified, and the amps right justified :p)
As I get my games away from the wall and figure out more serials I will edit this post and/or create a new post to update with more stuff to fill in on these (and to increase quantities). Thanks.
I'll take :
(2) #4 - (1) Printed with the following, and (1) blank : Model #: 383 XX, Serial #: 0001, Volts: 120, Amps: 3
(1) #5 - Model #: 38300, Serial #: 0000001, Volts: 120, Amps: 3
(1) #11/11a - Serial #: 00001
(1) #12
No slashes in the zeroes, if that was ever decided/debated/an option.
Its going it the good direction !
No problem, i have removed the slashes in the zeroes in the last run also
I do have a note, I don't have a typewriter, so embossing the serials in #4 will not be done by me.
I can however print the letters in there with a very simular font so they look embossed:
That sounds decent, and I also have an old typewriter I can use. Let's just bump it up to (2) #4's, one with the type printed on, and another one blank that I can type into later.
Previous post and totals updated.
