Alien Storm - Vertical Hold Issues
Detroit44
In Memoriam
Macomb, Michigan
I just picked up a copy of the System 18 game Alien Storm. I am using a standard jamma interface and it requires odd adjustments to Vertical Hold in order to be playable. For example, the top scoring part of the screen is separated from the playing field by the vertical hold. Thus, the scoring part of the screen can be moved (via the vertical hold) to be right on top of the action portion of the screen. No matter how hard I try - I cannot get the two pieces of the screen to line up correctly. Has anyone else expereinced this problem with a System 18 game? Thanks
Hopefully you don't have the surface mounted customs lifting off of the board. Could you post a picture of the problem?
