akkanoid help
If your game plays blind you most likely have a monitor issue like you think. First off welcome. Second, start by checking your voltage that runs to your monitor. If that checks out ok, then take a couple of pictures of your monitor and post them here. See if you can find out what type/brand and model number it is. Did you hook the new power supply straight to your monitor? I hope you ran it through the ISO first.
akkanoid
the monitor was a 19" g07-cbo my son was playing it was working fine ,then the srceen went plank?the power supply is hooked up right.thanks
i only see one fuse and it doesnt look blown?
There are two fuses. One near where the power wiring goes in, and another smaller one a little farther back next to the big capacitor. Be careful checking the small one, as that big cap might be holding a charge if it is blown. If you know how to discharge a monitor, then discharge both sides of that cap before testing it. If there IS a charge on that cap, expect a very big POP....
arkanoid help
i found the smaller fuse,but the fuse is soldered? im new at working on this stuff,do i have too take out the board?thanks for the help i thought losing a big fish is stressful these games can be too. lol lol thanks
