AF add the extra ball button mod instructions
Here is a cool link I found on adding the extra ball/continue buton to AF pins with gold roms to make them work like the gold models. I search here and couldnt find it so here it is,
http://www.home.earthlink.net/~pinball_stuff/TAFmod.htm
Really not a mod. That feature is built in the Addams gold software. Easy to add to a regular Addams Family. Just change the rom and wire in the 2 wires into the switch matrix. The button does not light up on the Addams gold models so nothing to worry about wiring that.
The machine will tell you.
Go to individual switch or lamp test, stop on the one you want. Hit the start button and then keep hitting the + diagnostic button, this will step you through wire colors, connector number and which pins used on the connector.
LTG :)
