Advice on a desoldering station?
Paradroid
Donor 2012
Portobello, Otago, New Zealand
G'day guys!
Long time lurker from Australia writing here...
Yesterday I introduced myself over in "Technical - Videogames - General Repair And Help" but I meant to introduce myself here... (oops!): http://forums.arcade-museum.com/showthread.php?t=256614
Anyway, if you check out my starter thread you'll see where I'm at with CRTs...
Although I'm just getting started in the world of monitor care and repair, I'm really enjoying the experience and would like to buy myself some fancy tools. In particular, I'd like to buy a de-soldering station and ESR meter. I figure electronics will always be part of my life (I also tinker with and service my own computers and musical gear) and I'd like to get gear that I really enjoy using and that can produce professional quality results.
So, when it comes to monitor repair (replacing caps, flybacks and such) what would be people recommend in the way of a de-soldering station?
I've been looking at the Hakko 474: http://www.hakko.com/english/products/hakko_474.html
Also, what ESR meter do people recommend? I've Googled but I still have no idea what the best model is... figured I'd ask the gurus.
Anyway, I'm happy to spend the money but want to make sure I get the right unit for the job.
Any dvice would be most welcome! :)
I don't think you can go wrong with any of the Hakko's. I have an 808, and I absolutely love the thing...time saver, easier on the boards due to quick and full desoldering, etc.
As far as ESR meters, I guess "best" is relative. I have the little Atlas ESR70 which is plenty for what we do with arcade caps. I've yet to "need" more than what it provides, but others with more experience may advise differently.
Also, try the KLOV search, there's TONs of stuff on these two topics to help confuse...I mean, help you make up your mind. :)
Another Bump and A+++ rating on the Hakko 808. So far, it's worked on everything I have thrown at it. It heats up fast, works great, and is easy to clean.
You'll have to order it - I used eBay and had good luck with B&D. Since you're getting it in Oz, make sure you order extra tips.
While you are at it, if you are getting serious and want to do good work, get yourself a good soldering station. I went with the Hakko FX-888, and I LOVE IT. It heats up fast, does a great job, and the tip cleaner is great.
Buy the set - you'll be glad you did it.
The Hakko 474 is a very nice unit. I bought the 472D (basically the US equivalent) and saved quite a bit of money, but it does require a stepdown converter.
I second the recommendation for the FX-888.
Thanks for the replies, guys!
Sounds like I can't go too far wrong with a Hakko soldering and de-soldering setup!
I appreciate the feedback as I didn't want to take the plunge and then find out that I'd thrown my money at a piece of junk.
Currently weighing up between the Hakko 808 and 474...
Thanks again for the advice guys!
I've now ordered the following:
• Hakko 808
• Hakko HFX-888
• Atlas ESR70
That should keep me occupied for a while! Looking forward to playing with my new toys... :)
