Adventures of Robby Roto Artwork?
Brandonh1091
Donor 4 years: 2013, 2015-2016, 2018
Anderson, South Carolina
I've got a Robby Roto cabinet that was converted to a Skykid at some point in it's life. I was able to remove a lot of the black paint with alcohol and Magic Erasers, but the original artwork is faded pretty bad, and the left side ended up having a good bit of it missing completely.
I'm fairly good at drawing, and since the artwork isn't terribly complicated, I was going to attempt to fill in the gaps on the artwork and try and redraw it myself, maybe with some paint pens or something. Then I can hopefully color match the orange cabinet color, and give it a fresh coat of paint. Worst case scenario, I'll paint it back black as much as I'd hate to.
I'm assuming there aren't any stencils available? I haven't been able to come across any personally. If not, do any of you guys know where some high quality scans of the sides might be? I thought about trying to make my own stencils, but all the reference shots I've found so far are fairly low-res.
