Adjusting the Path of Adventure on Indiana Jones?
TheDrewster
Donor 2012
Reno, Nevada
At first, I thought (and was thoroughly convinced) that I just purely suck at the game. But over time, I have noticed that my Path of Adventure truthfully doesn't tilt far enough to the right to allow the ball to travel along the right side like it does on the left side. 100% of the time the POA drains the ball down the center if you attempt to hit a right hand target. Is there a way I can adjust how far the POA tilts?
I seem to remember a set screw coming loose and causing a problem like what you are describing.
Rodger Kilgore
See if this helps
https://groups.google.com/forum/#!searchin/rec.games.pinball/adjusting$20POA/rec.games.pinball/uAeN-cZVamE/LCUrdh4s-tsJ
Once I got mine tightened back up on the set screw it worked fine but this has more info and gave me some clues to get started.
It is very easy to remove and checkout yourself as long as you remember to disconnect the wire bundle before you start unscrewing.
Kenny
