Level42
Don't know about that, but I know that I did the only proper thing:
http://forum.arcadecontrols.com/index.php?topic=62884.msg858916#msg858916
I do however use a "trick" on joystick adjustment that works great on Pac-Man too; if you remove the stick and bend the levers (leaf switches in the case of Pac) to bear on the shaft barrel harder, it gives the joystick a much better centering function. When you let go, it'll be back in the middle so that you'll always have the same throw to engage your next movement.
With Pac, people often think the rubber grommet has given up; some even make grommets of harder rubber. But putting a little tension against the barrel of the joystick gives a great feel to me.
It is not a good idea to use the switches this way. It reduces the life and the consistency of them.
The switch may be in light contact with the joystick shaft, but should never be under tension at rest.
Only the adjustment or replacement of the grommet or spring that centers the joystick should be should be done if stronger re-centering is desired.
Darren Harris
Staten Island, New York.
You are completely right. This is how I adjusted my Nintys. I forgot! I have bent the switch arm on other games, but never Nintys. You adjust them with the screws and slide it.
I've been thinking about adjusting my button recently and glad this post came along. I adjusted mine yesterday using these screws, and man does it make a difference. I put it right up on the button, so when the button is pressed it clicks pretty quick. It makes the timing a bit more accurate for me. Now time to get used to it...
I'm with ya Jeff. Glad the post helped.
I could not pull off that backwards jump that fast like in the video, before I made this adjustment. It's funny though that the button "sounds" different when I push it than it did before. Throws me off a little. Of course I notice it because I play with the sound off (to keep from waking up my kids).
This is a pretty interesting technique. I've no doubt it would be a great mod for your own cabinet, but it does make me wonder what affect it would have on playing ability with a different cab, especially if you were competing. Your timing would be ever so slightly off maybe?
Still, I may give this a shot. A super responsive jump button is very appealing!
Well, I know only 2 DK cabs in The Netherlands (mine is still a MB, but that will change to DK) so I'm not too worried about that. I'm not a hi-score player anyway. Even so: IF I would have to compete, I can always bring my own CP. (Something I'm pretty sure every top player does ? It's like using your favorite brand of tennis racket, players are allowed to choose their favorite as long as it sticks to certain rules).
I just generally hate micro-switches and will replace them as much as possible with leafs.
(I would surely put them in my SW yoke if that were possible !)
Blasphemy or not, I don't care, as long as it is reversible AND as long as I can play as comfortable as possible. I would do the joystick as well if possible, still looking for a way to get that done.
Micro-switches. Yugh.
