KenLayton
In Memoriam
How to add a "+ 5 volt" indicator for the Gottlieb System 80 Generation 1 CPU board (the D102 board). This will light up when + 5 volts are present on the CPU board.
Materials needed:
1 Red LED, Jameco # 2125309 or Radio Shack # 276-209
1 Resistor, 330 ohms, quarter watt, Radio Shack # 271-1315
Drill two 1/16" diameter holes spaced about 3mm apart in the spot indicated just below power connector J1. This area has no traces to interfere with drilling.
Install LED into board with flat side facing toward the power connector J1.
Bend the flat side's lead to the negative (ground) point shown in the picture and solder it.
The other lead of the LED will connect to one side of the 330 ohm resistor. The other end of the resistor will be soldered to the positive trace shown in the picture. You're done.
Now whenever the machine is powered on, this LED will indicate that the CPU board is receiving +5 volts from the power supply.
Materials needed:
