Added manuals and schematics to my website
musicman282
Akron, Ohio
I found a bunch of manuals, schematics, monitor info and dip switch settings and have a bunch of extra space left on my hosting server so I posted them up for people to download. If anyone has stuff I'm missing that they'd like to see hosted, just shoot me a PM and I can put up the information.
Enjoy.
http://donkeykongkillscreen.com/?page_id=133
I have a few documents that I don't see there but I have a few questions...
Can you alter the page? I am seeing a blue background with blue text, it is excruciatingly hard to read.
Can you subcategorize things? Simlar to the arcade archives - it makes finding what you are looking for much easier.
I'll take the time to locate the files I have that are missing and send them to you. I know I have a Moppet wiring diagram and a few others.
What browser are you using? Mine shows up as blue on white...
I'll try to edit the settings. Do you normally have issues viewing wordpress sites?
I can definitely make sub-categories, I just have to find the time and it's basically a matter of just breaking up the main folder into sub folders. I just got all the documents uploaded, it took all day cause my upload speeds are horrendous. Thanks for the comments. Check it now and see if the background is better. It was set to blue, but didn't show up for me!! I guess I need to test it in different browsers.
I am accessing from a work computer. IE is the common browser I use.
Did you pull a layer from another site? Sometimes pages only partially load due to the restrictions placed over this network. If you pulled a color layer, picture, or anything else from a site I am restricted from accessing it will simply be left out and this can cause pages to load oddly. In the past I have seen restricted pics tiled on a page as wallpaper be left out and this caused a similar contrast issue to what I am seeing on your page.
That is definitely the issue then. The default background color was set to blue and the actual background of the page is an image of a wizard of wor cabinet and that must not be showing so it defaulted to blue. I changed it to off white now so it should be better.
It would be helpful if you created a separate site for all the monitor stuff. While a lot has "monitors" in front, there are a bunch in the W's and U's that is monitor stuff that doesn't. A separate page just for monitors would be best.
And why is there a break toward the bottom with another list? If one is manuals and another schematics, some headers would be nice to differentiate...
Thanks for the suggestions. I'm definitely going to clean up the organization of them and go through them a bit. I just have to find the time.
I'm looking for a MayDay! manual (the Defender clone). On the very last page is a schematic of the Nintendo Sanyo monitor with the optional components installed to accept normal arcade video directly. The manuals of this game hosted elsewhere are scanned in such low resolution to make the schematics worthless.
