addams family ramp question
firepowerplayer
iron station, North Carolina
My addams family bear kick ramp drops the ball into the playfield. I found that it is missing a long ramp support over where it would drop out over by the little thing flipper. It mounts on a small raised up peice that screws into the side rail, and has a threaded rod sticking out to hold the ramp support. I cannot find the correct part # or any place to get them.
Thank you for any help you can provide.
I think you are refering to the hex post at the lower end of the ramp? A 1 1/2" hex post?
spacer f-f 8-32X1-1/2 1/4hex
That would be part number 02-4436-7
available here: http://www.marcospecialties.com/product.asp?ic=02-4436-7
The other supports for the ramp are the bracket at the diverter which I think is part number 01-10427 but not sure. Then there are two hex posts at the top of the ramp, one on the left, 2.83" long, part number 02-4436-5, and a 3 1/2" post with a threaded bottom on the right, part number 02-4611-1.
Phil
