Addams family flipper problem
vivagolf
North Carolina
My TAF was working great. Turned it on and everything seemed fine except when I went to use flippers there was nothing. Flippers will flip during the music but nothing else.
I replaced the flipronics board with a new one but still nothing. The only thing I did in between was replace the coin door.
Any help would be appreciated.
Thanks,
check any connectors from coin door to coin door interface board
check flipper board behind button for any broken parts
If not the board (fuses look good? Are Flippers energized / stuck up?) check the leaf switches by the buttons. They need precise adjustments and can be stuck closed (i am not sure if TAF is normally open or closed - just sold mine).
I had similar issue and drove myself crazy checking electronics when i found out it was just adjusting those switches...
Maybe it helps?
Give this a shot. Lift the playfield and clean the flipper optos with a Q-tip and alcohol. Also reseat all of the ribbon cables in the backbox.
Thanks for all the replies. I did the checks and came up with this.
Well, finally on the error report, when you first turn on the machine, it states check F2 and F4 flipper button. It never stated anything like that before. Is it possible that they both went out at once or is there some common problem that I could check for.
Thanks again,
