addams family filpper ?
HAVASUGAMEMAN
lake havasu city, Arizona
ok what would cause the upper left flipper to energize at power up?that is the only one to do it all the other three work fine.I replaced the coil with new thinking it was shorted,did not fix it.checked wiring seems to be correct looked for fried trans. did not see one. have looked at schematics but did not find witch trans controlled it.was hoping someone here can help .thanks
Very rarely does a coil fail. Look for your Fliptronics board. Bad transistors must be tested they don't "look fried". Chance are that you have a blown TIP102 or TIP36. I don't remember which pair control the upper left flipper, but if you test all 8 you'll find your problem pretty easily.
