I'm getting a Midway MK2 cab back in order and wet to Menard's today to replace the marquee bulb. Installed it and, flash-- gone. Took another working bulb to be sure and the same thing happened.
I checked the AC at the connector at the light assembly and it's reading 137.5 Volts. Checked it at the switcher and at a open connector at the transformer block with the same result. What could be causing the voltage to be stepping up from 120V?
I don't want to screw up the monitor so I unplugged everything. I checked voltagess on the switcher and everything on the DC output side is correct, just having some over-voltage issues on the AC. Outlet in the house is normal additionally. The bottom of the Txsformer has the AC line filter coming in. What would be the correct pinouts to trace back to the original 120v? thanks!
