About to buy first pin
Lazerhawk
Austin, Texas
Its an Elvira Party Monters described as having a perfect playfield that needs new rubber and playfield cleaning with wear around leg mounts on cab. Displays, sounds, drop targets etc are all working but there is some issue with playfield lights turning off intermittently. Im pretty sure he meant all of them. Does anyone have any idea what might be causing this and how much it would cost to fix? The seller thought it might be a connection issue in a harness but hes not sure so I'll be taking on this problem if I buy it.
By "all lights" - all CPU controlled lights, all GI lights, or *ALL* lights?
Assuming it's GI, it's not uncommon for those connections to cook, and require the header pins be replaced, and likely the harness connector as well. Pretty cheap, easy, and straightforward.
anyone know how tall the cabinet with the back box folded down is? I need to know if I have to take my camper off or not. I only have 31" of clearance cant imagine it being that big
