Well, since you asked, here's my picture. It may result in boisterous laughter from pinball purists, but after having a pin with LEDs right next to this one, this one just looked.... bad. I HAD to do something. Some of the whites were just too damn white, so I changed the colors. You'll notice the elevator lights, for instance, have color now... also, I made the taxi chase orange instead of white. For the rest, they're all original colors. The clues and the equipment in the game aren't as overly white as this picture would suggest, and I had to tone down the faces so they didn't get too bright... because, unlike other others, those WERE too bright.
EDIT: one thing you don't see here is I added a LED flasher in the phone, too. Looks awesome when it rings. No bleeding of color from under, as I put a piece of tin foil under it to shield light from coming out. Sounds lame, but you can't see any of the foil as it's totally concealed from any angle you could possible look. You'd have to take the phone up and off and hold it in your hand to see it.
