Level42
Will a A50-120W tube work as a substitute for a 19VARP4 or M47EAA19WS BW tubes as used on vector monitors ?
I understand it's a bit larger (50 instead of 47cm. but I think/hope that's no problem) The A says it's a TV tube (where M is Monitor AFAIK). Is there any quality difference ?
Here is the data sheet of the Telefunken A50-120W:
http://tubedata.tubes.se/sheets/124/a/A50-120W.pdf
AFAIK all BW tubes use the same socket/Pin out ?
