kennyp2112 Member VAPS Joined Jan 3, 2008 Messages 868 Reaction score 11 Location South Milwaukee, Wisconsin Aug 13, 2009 #1 I took this tube out of a Goldstar TV manufactured in 1984. I can't seem to find anything on it ...I.E if it can be used for an arcade monitor. Many thanks for any help Ken
Space_cowboy New member VAPS Joined Mar 29, 2003 Messages 3,537 Reaction score 2 Location Calgary, AB, Canada Aug 13, 2009 #2 depends on the neck pinout, you have to match that to chassis
KenLayton In Memoriam Joined Dec 14, 2003 Messages 20,220 Reaction score 712 Location Olympia, Washington Aug 13, 2009 #3 Sega/Nanao MC-2000-S can use that tube (B&K crt adapter CR-25) but be sure to double check the yoke measurements. The MC-2000-S uses a 50 ohm vertical yoke (high impedance).
VectorJunkie Well-known member VAPS Joined Jul 8, 2007 Messages 7,062 Reaction score 94 Location Texas Aug 13, 2009 #4 kennyp2112 said: I took this tube out of a Goldstar TV manufactured in 1984. I can't seem to find anything on it ...I.E if it can be used for an arcade monitor. Many thanks for any help Ken Click to expand... If you find a compatible chassis/yoke, let us know. Those tubes can be purchased for $64 rebuilt. Edit: Here is info on the socket adaptor that Ken mentioned and the other tubes that use it. http://arcarc.xmission.com/PDF_Monitors/BK_Precision_CR-25_CRT_Adapter.pdf Edit Again: Those are zeros in the part number BTW... A48ABY00X Last edited: Aug 13, 2009
