paulcan2
Morning people, I'm based in the U.K and a member of Jamma+, U.K Vac and Arcade Otaku
(as paulcan69)
In the U.K there aren't loads of Atari A.P.B cabinets left, however I'm the lucky owner of one, I have read on here before that the main problem with these is the triacs on the triac board and that seems to be the common fault with these.
I have already ordered and fitted two n.o.s triacs have fitted them but my fault seems exactly the same, I haven't spent any time yet checking anything (voltages etc... yet) but just wanted a flavour of what you guys think it maybe, or what to check next.
I have one light on in a solid state, the other lamp does flash and act as it should do but is very dim, I have swapped the bulbs over and nothing changes so it must be PSU/wiring or triac board related.
What voltages will it be? As it's a U.k machine I'm guessing 240vac to the marquee lights?
Any ideas, as I know you have alot more A.P.B cabs over the pond?
Many thanks for any help in advance,
Paul.
(as paulcan69)
Paul.
