A little help on CPU IC info
GoneMad
Cavendish, Prince Edward Island, Canada
I just received a small order yesterday. Part of the order was two 6809E cpu's for my Double Dragons. Turns out they have no 6809E in stock and sent two 6809P instead. From what I understand, what I need in the E series is external clock, and what they sent has internal clock generator and will definitely not work, right? They seem to think it should, but I'm not even gonna try till I can confirm. Thanks.
Correct. Will not work and they have slightly different pinouts.
You can get a 6309E if they have those. They are an upgrade CPU though so I'm not sure if they'll speed up the game slightly or not.
RJ
