modessitt
Is there a way for me to test these? I'm trying to fix a T2 with guns that don't move. Wiring is good, fuses are good, pots have been replaced. I swapped out U1, but don't have a U2 on hand to swap. I assume this is used to convert the motion of the pots to a digital signal for the CPU? I should be able to check the outputs to see if I get changes while the guns move, right?
