MonsterBash
I need to move the picture horizontally about 2 inches (long way). I see there is a set of pins (which i have) but I don't have he jumper wire. Can I just add the wire to the upper pin on the coil and make my own jumper
#2 The monitor scrolls vertically (the short way)..no matter how 'little' I adjust it I just can get it to stop. Even if I get it to stop it'll slowing start scrolling again and I can't ever get it to stop in the center
I did cap the chassis..reflowed what seemed like 1000 solder points. I looked at Bob Roberts 'sync' page and messed with the L351 but it didn't help
Also under the vertical hold, on the solder side, there's a resister im not sure if it's supposed to be there or if someone added it.
This is a 60-in-1..I've tried the sync on both pin 5 and 6 (R,G,B,Gr,Sync,NC and R,G,B,Gr,NC Sync)
