Are there instructions on how to install the 96-in-1 Multi-Pac kit? Can someone shoot them my direction if possible?
Hey guys... I have a Pac Plus going and the docs only mention Ms. Pac and Pac... not Pac Plus. Should I consider a Pac Plus a "Pac" or a "Ms. Pac" when installing this kit?
Shoot me an email at: [email protected] and I'll send you the full copies of the manual.
Pac Plus is the same board as Pac and Ms Pac, the only difference is going to be the color PROMs at 4A and 7F since Pac Plus uses unique code.
Follow the regular instructions for a Ms Pac board and swap out those two color PROMs.
Maybe I am over analyzing this but according to the Ms. Pac instructions, there should be a daughterboard that this Pac Plus doesn't seem to have... I think you mean I should follow the PAC instructions except for those two color PROM's...which I then want to follow the Ms. Pac instructions, right?
Alright... I finally am getting around to installing this kit on the Pac Plus and I've come to a couple issues.
(A) Where do I get the proper color proms that I need to replace?
and the more important issue...
(B) Step 2 has me removing the Z80 from the mainboard to put on the kit... the problem is, there is no Z80 on the mainboard... If there is, I can't find it. There is a ribbon going from the main board to a black epoxy covered "brick" ...and if my assumptions are correct, the Z80 is in there? Or is it stuck under the satellite board on the other side of the mainboard?
If it is in the "brick"...how do I get to it and/or where in the heck do I get one?
Unless you can plug that whole pac-plus board into the Z80 socket. I'm not sure I would try it unless someone else says that is what your supposed to do. I did check the conversion documentation from pac to pac plus and it says to pull the Z80 and return it to your stock as a spare part.
-VJ
Yeah...I don't think I am going to try to plug the pac plus daughterboard in to the multipac daughterboard.
I'll just have to source the parts.
I would suggest pm'ing Riptor. Explain the situation and he could probably hook you up with everything you need.
