9200 color transistors
roothorick
Wisconsin
This makes sense in my head, but I thought I'd run it past people smarter than I.
I've got the color-out issue on one of our two 9200s. I already made a thread about this monitor here but I got a different question now. mecha187 suggested replacing the resistors with a higher resistance and replacing the color transistors with a beefier NTE2501 (higher max voltage). However, as he admitted, it won't look as good, and since this is an in-the-field machine that's expected to make money, that's not desirable. I want to take a slightly different approach -- use the current 1.35kOhm resistors, replace the color driving transistors with NTE2501s as they die, at the same time fitting them with significantly larger heatsinks (I'm thinking 3W@25C). Will that work out? Could the larger hunks of aluminum screw with the magnetic fields in the tube?
-E- You know, I now have a 9400 neckboard that doesn't have a tube to go with it. It has "H." (Hitachi?) 2SC2682s on it. Slightly lower voltage tolerance, but it just might work.
Larger heats sinks are fine. You should have any interference issues....
I had the same problem on a couple D9200s. a 3rd one actually hasn't given me any problems in the last 2 years (almost).. but anyway, I talked to Chad at arcadecup about this, and apparently there's two causes for why these burn out quickly on some monitors.
one, the factory resistors kinda suck, I used these as a replacement: http://www.mouser.com/Search/Produc...K5Evirtualkey58810000virtualkey588-TWM10J1K5E
I went ahead and replaced all 3. then, the next thing to do is to go into the on-screen menu and turn down the RGB values. I wanna say stock they run at about 3/4 of the way (whichever value that is) dialing those down will put less stress on the drive transistors.
I figure for the money you'd be better off replacing all 3 resistors and transistors and just be done with it. not that I object to your idea about the bigger heatsinks though, I'm just letting you know what I did on 2 horrible monitors we got in some Sega NAOMI games in our arcade that worked. :)
