dyno Well-known member VAPS Joined Apr 11, 2009 Messages 1,644 Reaction score 82 Location Lower Mainland, Britsh Columbia Mar 21, 2025 #1 Working on a pac man board and I believe one of the 82S25 (74S89) ICs could be the problem. Would a 74LS189 or 74LS289 be a direct replacement? They seem to be more available.
SNESNESCUBE64 Well-known member VAPS Joined Sep 25, 2018 Messages 2,578 Reaction score 3,279 Location Michigan Mar 21, 2025 #2 I think both 74S189 and 74S289 are compatible. Edit - Read post below. Last edited: Mar 21, 2025
HudsonArcade Well-known member VAPS Joined Aug 12, 2009 Messages 14,729 Reaction score 3,631 Location 01749, Massachusetts Mar 21, 2025 #3 SNESNESCUBE64 said: I think both 74S189 and 74S289 are compatible. Click to expand... In this design 189 will work, but 289 is closer. 74s89 and 74s289 are open collector 74s189 is tri-state 82s25 and 74s301 are open collector 74s201 is tri-state.
SNESNESCUBE64 Well-known member VAPS Joined Sep 25, 2018 Messages 2,578 Reaction score 3,279 Location Michigan Mar 21, 2025 #4 HudsonArcade said: 74s189 is tri-state Click to expand... Oops, missed that one. Thanks for the correction. It bothers me because I looked for that...
HudsonArcade Well-known member VAPS Joined Aug 12, 2009 Messages 14,729 Reaction score 3,631 Location 01749, Massachusetts Mar 21, 2025 #5 SNESNESCUBE64 said: Oops, missed that one. Thanks for the correction. It bothers me because I looked for that... Click to expand... Meh -- Tri-state will usually work in place of OC. OC won't work in place of TS if the pullups aren't populated.
