809 Power Problem
ukman
Georgia
My 809 does not power up. I checked all 3 fuses and they were good. 120v input was good. Is the output voltage 50v? The interlock switch is located on lower front. I tried the reset switch on top right. Unit is dead. Any suggestions on where to start?
There is a bar on the hopper. If you push it in it will reset the hopper cut off switch. You can verify this is the problem by looking in the back of the machine on the bottom behind the hopper. If you see a small light builb lit that is your problem.
