73 Midway Duck Hunt help
justaguy
Saint Clair Shores, Michigan
If anyone has one that could take a picture of (D-26-700 current limit resistor coil) mine
has a few wires that came off, or a schematic that could scan for me
Thanks,
Dan
Update
I now know where the wires connect to, Big Thanks to Rj. I have a new problem the first coil appears to be shorted.
Does anyone know where i can get a replacement pbresource does not have one, Is there another place out there that has them? My knowledge is very limited to the function of this
Dan
I would check with John Robertson at flippers.com. Good chance he might have one.
Otherwise you can rewind the coil. I have just had to do this for another EM game. Not hard to do , but just takes a couple of hours. Let me know if you need more details.
regards Derek
regards Derek
Would it be possible to use a couple of wire wound resistors at 7k each at 5 to 10 watts?
Or a couple of 7K .... 5 to 10 watt cement resistors.
RJ
mmmhh Same part number D-26. You could try it as it sits. Measure the coil resistance of the new coil. 1k might not make that much of a difference. Let us know how it turns out.
I am going to make an attempt to finish my Duck Hunt, this spring. I screwed up and reinserted the lens tube the wrong way and now it is stuck. Everything else works.
RJ
Or could I use this one
http://www.marcospecialties.com/product.asp?ic=D-26-800
and take off 100 turns of wire?
looks identical to mine
Dan
RJ
That sucks hope you can get it un-stuck
I emailed them Just waiting to here back, Im thinking D-26-800 is my best option to
