This monitor does not fall in that category. A common failure on this monitor is to check/change C009 (22uF @ 50V) and C013 (100uF @ 25V). These caps act as filters for the PWM chip in the power supply. If it is chirping at you, check your HOT at Q603 (2SD669).
replaced q603 with a spare i had from a parts board and nothing. its possible i guess that hot could be blown also. is there a way to check it on the meter?
You can check it with the diode tester on your meter. If you changed those caps in the power supply and the HOT, you could also check all the diodes and safety caps that sit next to the HOT. D601,D602, D603, D604, C601, C602, etc.
