7201 yoke question
BobsterD
New Mexico
I am swapping out a tube on a 19" 7201 (broken neck) with a donor tube from a TV... the 7201 yoke measures 13.3 on Y&B, 2.3 on B&R.
The donor tube yoke measures 14.5 on Y&B, 3.3 on B&R. Are these specs "close enough" or should I swap yokes? I'm hoping to to so I don't have to work on convergence as I suck at it.
Thanks in advance!
Try it without swapping the yokes and see what you get. Best case scenario things are close enough and you don't need to worry about convergence, worst case scenario you blow the TV yoke and need to replace it with the 7201 yoke, either way your chassis should be fine.
