720 sound problem
Bodie
Wichita Falls, Texas
My 720 has no sound except coinup (taco bell sound), also zero control from stick, anything jumping or crashing distorts slightly.
I have tested the harness, +5 is great, reversed speaker wires to verify speakers, and have continuity through the harness. In test mode I hear sounds and speech, but is garbled at the end of words.
I have tried three different LETA chips (may all be bad).
Buttons and coinup works fine.
Any Ideas will be appreciated.
Thanks!
Update : fixed sounds by replacing chip 6116 row 1 second from last chip on CPU PCB.
Update 2: fixed control, the plugs on the optic board had been reversed. I was getting good voltage so i switched them. Wala its works!
Any Ideas on the other problem?
you might try replacing your dual coupler board. does the stick zero out in test mode?(im sure it dosent just asking?)
i would start with the dual coupler board. did you check your voltage at the coupler board?
cr
Are you refering to the optic board? I have not tested any voltages there. Not sure how to test that board. I can find a ground, then can I test each point on the 2 plug as positive?
Thanks!
yes dual optic board, check your voltage there if its below 5+ you might try turing up your voltage. my guess is your optic board is fried.
cr
If you happen to need new opto's, I have NOS ones that are used on 720 and other later Atari games. They are part# C020290.
Brian
graphic problem
Anything jumping or crashing distorts slightly have went through all roms, and still have graphic glitch.
Any Ideas would be appreciated.
