720 sideart placement help
Jedidentist
Donor 3 years: 2011-2013
Sudbury, Massachusetts
To all of you 720 owners out there. If someone has their original sideart intact, can you get the measurements of how far down it is from the top and in from the back? I know I could just place it so that it looks about right and do the same on the other side, but figured that it might be worth throwing the question out there...might as well try to get it spot on. Thanks!
Derek
Never mind...not only did I post this in the wrong forum, but I found some pics of unrestored ones and just eyeballed it. However, I measured the one side to make sure it exactly matches the other.
