supadave1
Can you swith out a wg19k7600 chassis with a 19k7000 safely? Would there be an issue with the vertical ohms or anything like that or should it just be a straight switch out and match up to the tube fine. I got a remote customer that I need to talk through a change out and I'm hoping to just do a straight chassis change out. So if I send him a 7000 thousand I would like to know if it would be a straight swap out with a 7600. I"m hoping one of the monitor guru's here can give me some insight. Thanks...
