Here's a tip a issue I ran into: to multi a mk what I had to do was jump the -5 for the sound to work then in order to be able to use the settigs I had to jump the service pin to all but make sure you throw diodes in between if not it will shadow and cause you not to exit out of settings, it's just easier to do other the hooking each one up to set the settings the go back and hook it up to your 6in1, then do the same for the kick harnesses when you splice them together put diodes in saves alot of hassle and changing and unplugging crap when you want to switch games
