andrewb
I have several 6100 HV cages available.
These I'm selling outright because they are spares that I put together from parts and boards that had been stripped. As a result, they all have new flybacks (which is usually not necessary when refurbing existing cages, because they rarely go bad in these). These cages do NOT include mesh covers. I also have a couple of spare deflection boards available, PM for details if interested.
If you are interested in trading in your dead HV/deflection/neck set for an already refurbed set, I also have a couple of complete sets ready to go, see this thread. (That thread is old, but the details and pricing are still valid.)
For these monitors, I strongly recommend rebuilding all 3 boards (deflection/neck/HV) as a set. Mixing rebuilt with non-rebuilt boards can result in damage to the rebuilt boards, if any other board in the system fails. These boards are very interdependent on each other, so for best results you generally want to treat them as a set. So if you are having problems with your 6100, do not just buy a new HV cage to see if that will fix things. You are only more likely to end up with more blown boards. PM me and I can help you fix it properly.
Three cages available. I'm only posting pics of one, since they're all basically the same. I give these all the same treatment and warranty.
- Thoroughly washed and dried
- NOS Arcadeshop flyback
- Fully rebuilt with all new high-hour Nichicon and Panasonic 105-degree caps, new Zener diodes, and new small-signal transistors
- New HV pot
- New silpads installed on both cage-mounted transistors (replacing old mica insulators + thermal grease)
- HV has been calibrated to the proper level (so you don't have to)
- Burn-in tested in my personal monitor for several days
I will warranty each of these for two years. If you have any problems, just pay to ship it back to me, and I will repair and return ship for free.
$265 each shipped. Int'l shipping extra.
$195 each shipped with trade-in of a complete but non-working HV cage. PM to discuss details.
- New HV pot
